Hi Guys,
I hope you all can assist. I am trying to install ESXi with a Cisco unity connection VM on a UCS blade series that is installed on a 4K router. So far the CIMC is good and I was able to install the ESXi. And I configured the UCSE 1/0/0 interface to use unnumbered from the voice interface on the router. I am able to get communication out from the ESXi since it is on the same network as the unnumbered interface. Also the CUC should be fine. But I want to allow multiple VLANs on this ESXi host. So in addition of voice, I want to assign the ESXi to a management network and also install other virtual machines that are on different VLANs.
How can this be done, is there a guide out there with these steps, the cisco guides are not very clear.
