Cisco Voice Gateway Firmwares
Hello Folks,
I'm picking up Cisco from my ex team mate and learning voice gateways.I'm from 3com and H3C background.
Can I know below firmware good to run on Cisco voice gateway 2800,2900 and 3900 series?
15.1(4)M10
My voice gateway running below IOS currently.
2800 series   - c2800nm-ipvoicek9-mz.124-15.T7.bi
2921   - c2900-universalk9-mz.SPA.152-4.M5.bin
           - c2900-universalk9-mz.SPA.150-1.M4.bin
2951   - c2951-universalk9-mz.SPA.150-1.M3.bin
           - c2951-universalk9-mz.SPA.150-1.M6.bin
3951   - c3900-universalk9-mz.SPA.153-3.M3.bin
           - c3900-universalk9-mz.SPA.152-4.M8.bin
           - c3900-universalk9-mz.SPA.154-3.M3.bin
           - c3900-universalk9-mz.SPA.152-4.M4.bin
Any on running  and tested 15.1(4)M10 firmware?Any bug for voice gateways?
Please advise.
Iniyan
Deepak Rawat
Adding to what Manish said, once you will go to the Cisco Website to download IOS for the respective router you will see some of the IOS versions marked with STAR that means they are the most suitable and recommended ones by Cisco. Below link shows this thing for 2921 ISR
https://software.cisco.com/download/release.html?mdfid=282774229&flowid=7443&softwareid=280805680&release=15.5.3M1&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Deepak
Manish Gogna
Hi Iniyan,
It is important to check if these gateways need to work with CUCM or CME, based on that the recommended IOS version can be specified as per the following link
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-express/products-device-support-tables-list.html
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/Compatibility/CSR-Compatibility-Matrix-InteractiveHTML.html
Running one of the latest versions is recommended as it includes max bug fixes and new features.
Manish
Thanks folks for the Answer.Very helpful.
Iniyan
Deepak Rawat
Deepak
