ā07-16-2016 08:27 AM - edited ā03-19-2019 11:21 AM
Hi All ,
how can i get the software of Cisco unified attendant console version 11 both server and client side as i cannot find it at Cisco website? also the compatibility with CUCM and Windows server?
Best Regards
Essam
ā07-16-2016 01:48 PM
The installation guide has all the info regarding requirements, you need to review it and follow it for the installation.
The files are at www.cisco.com/go/ac
ā07-16-2016 02:04 PM
ā07-16-2016 01:56 PM
Cisco Unified Attendant console Advanced version 11.0 can be downloaded from the following link:
http://arcsolutions.fileburst.com/downloads/CUACA_SV_11.0.1.10.zip
The windows server requirements are mentioned in the install guide for CUAC.
Cisco Unified Attendant Console - CUCM compatibility matrix:
ā07-16-2016 02:02 PM
Thanks Shashank Mahajan for your response.
wonderful links but the compatibility matrix does not contain CUACA version 11
Best Regards
Essam
