04-03-2012 12:41 AM - edited 03-19-2019 04:41 AM
We are changing Unity 8 partner from exchange 2007 to exchange 2010. We installed the ES10, uninstalled exchange software, ran the server update wizard, installed the latest version of ExchangeMapiCdo.exe, ran permissions wizard, created mailbox for UnityMsgStoreSvc, created the throttling policy and then ran the message store wizard.
The exchange 2010 server version is SP1 with rollup 6.
The problem is that the unity is returning Information Store on the Partner mail server is offline. Two events are reported in the event viewer of the unity server:
Now I set to 1 the registry key HKLM > Software > Active Voice > AvWm > 1.00 > Disable Server Status Check (DWORD) to disable the server ping check and to make AvWm assume that all Exchange servers are up all the time. Other events appeared in the event viewer including event ID 137 described as follows: Attempts to deliver Unity Message Repository messages have failed due to Unity configuration or connectivity issues with the Partner Mail Server. AvUMRSyncSvr will suspend message delivery for 300 seconds, after which message delivery will be attempted again. During this outage, messages may accumulate in the temporary store. 0x00002580
When I reset the same registry key to 0 I get warning events ID 1004 telling that each exchange server in my organization is offline. I also used the RPCtest.exe utility and it’s returning that the partner server and every other exchange server are online.
Does anyone have any idea how we can solve this problem ?
04-10-2012 02:10 AM
Dears,
Please advice if anyone has an idea about the issue we are facing.
Thanks in advance,
04-10-2012 06:10 AM
Couple of questions:
1. Did you follow the integration guide for this integration? The required tasks are outlined here: http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/using_exch2010/usingex2010withcu7x5x.html#wp46611
If you have not already done so, you'll need to make sure you cover all of the bases in the integration guide.
2. If you are migrating from 2007 to 2010 then you should have already had a mailbox for the message store service. Did you move the existing mailbox over to 2010 as noted in the integration guide? I ask because you state that you "created" a mailbox in your original post so it is not clear.
Hailey
Please rate helpful posts!
04-10-2012 06:51 AM
Hi David,
Thank you for your reply
1- Yes we followed the integration guide.
2- I was surprised for not finding a mailbox for the cisco unity mail store service user so I created it on exchange partner server in the partner database. And also the other unity mailboxes created by the message store wizard are on the same database.
Waiting for your help
03-24-2014 01:02 PM
Hello Mirna,
I know this issue is old; what was the resolution for your problem? We are experiencing something similar.
Thanks!
