Cisco Unity Connection 10.x Process Names
Tom W.
Hi Everyone,
Does anyone have a list of the actual process names that are running on CUC 10.x?
Tom
6 Replies 6
Dennis Mink
here you go:
System SSH [STARTED]
Cluster Manager [STARTED]
Cisco SCSI Watchdog [STARTED]
Service Manager [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco AMC Service[STARTED]
Cisco Audit Event Service[STARTED]
Cisco CDP[STARTED]
Cisco CDP Agent[STARTED]
Cisco CallManager Admin[STARTED]
Cisco CallManager Serviceability[STARTED]
Cisco CallManager Serviceability RTMT[STARTED]
Cisco Certificate Change Notification[STARTED]
Cisco Certificate Expiry Monitor[STARTED]
Cisco DRF Local[STARTED]
Cisco DRF Master[STARTED]
Cisco Database Layer Monitor[STARTED]
Cisco DirSync[STARTED]
Cisco ELM Client Service[STARTED]
Cisco Log Partition Monitoring Tool[STARTED]
Cisco Prime LM Admin[STARTED]
Cisco Prime LM DB[STARTED]
Cisco Prime LM Server[STARTED]
Cisco RIS Data Collector[STARTED]
Cisco RTMT Reporter Servlet[STARTED]
Cisco Serviceability Reporter[STARTED]
Cisco Syslog Agent[STARTED]
Cisco Tomcat[STARTED]
Cisco Tomcat Stats Servlet[STARTED]
Cisco Trace Collection Service[STARTED]
Cisco Trace Collection Servlet[STARTED]
Connection Access Layer[STARTED]
Connection Administration[STARTED]
Connection Branch Sync Service[STARTED]
Connection CM Database Event Listener[STARTED]
Connection Conversation Manager[STARTED]
Connection DB[STARTED]
Connection DB Event Publisher[STARTED]
Connection Database Proxy[STARTED]
Connection Diagnostic Portal Service[STARTED]
Connection Directory Feeder[STARTED]
Connection File Syncer[STARTED]
Connection Groupware Caching Service[STARTED]
Connection HTTPS Directory Feeder[STARTED]
Connection IMAP Server[STARTED]
Connection Inbox RSS Feed[STARTED]
Connection Integrated Mailbox Configuration[STARTED]
Connection Jetty[STARTED]
Connection License Manager Server[STARTED]
Connection Mailbox Sync[STARTED]
Connection Message Event Service[STARTED]
Connection Message Transfer Agent[STARTED]
Connection Mixer[STARTED]
Connection Notifier[STARTED]
Connection Personal Communication Assistant[STARTED]
Connection REST Service[STARTED]
Connection Realtime Monitoring APIs[STARTED]
Connection Reports Data Harvester[STARTED]
Connection SMTP Server[STARTED]
Connection SNMP Agent[STARTED]
Connection Server Role Manager[STARTED]
Connection Serviceability[STARTED]
Connection SpeechView Processor[STARTED]
Connection System Agent[STARTED]
Connection Voice Mail Web Service[STARTED]
Connection Voice Recognition Transport[STARTED]
Connection Voice Recognizer[STARTED]
Host Resources Agent[STARTED]
MIB2 Agent[STARTED]
Platform Administrative Web Service[STARTED]
SNMP Master Agent[STARTED]
SOAP -Log Collection APIs[STARTED]
SOAP -Performance Monitoring APIs[STARTED]
SOAP -Real-Time Service APIs[STARTED]
System Application Agent[STARTED]
Cisco Prime LM Resource API[STOPPED] Service Not Activated
Cisco Prime LM Resource Legacy API[STOPPED] Service Not Activated
Connection Digital Networking Replication Agent[STOPPED] Service Not Activated
Connection Exchange Notification Web Service[STOPPED] Service Not Activated
Please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
Thank you. Are these the actual names that will get reported, say if someone was monitoring the server through a monitoring software like SevOne?
Hi Tom,
You can use SNMP
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-connection-version-7x/113580-mib-00.html
http://www.cisco.com/image/gif/paws/113580/mib-00.pdf
http://www.ciscounitytools.com/Applications/CxN/RSK/Help/CISCO-UNITY-MIBContents.html
(Rate if it helps)
JB
Hi JB,
Right, I understand we can use SNMP. My question is when SNMP polls CUC what are the names of the services that gets returned? As Dennis posted above from CLI it's the list of services. I'm wondering if a monitoring software will see the same list when polling the CUC via SNMP?
Tom
Hi Tom,
You use MIB's to collect that sort of data like service down, server down.
Read below for details.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/10_0_1/admin/CUCM_BK_CDDBCDEB_00_cisco-unified-servicability-merge-100/CUCM_BK_CDDBCDEB_00_cisco-unified-servicability-merge-100_chapter_0111.html
(Rate if it helps)
JB
I know that...
What I'm asking for is what are the names of the services that show up in the monitoring software when the MIBs are picked up via SNMP for CUC. Your link is for CUCM.
