cisco unity connection 2.1 not transfer to greeting
jtroncoso
Hi.
I have a issue with cuc 2.1 the incoming calls have this flow   PSTN>GW 2821>CUCM> CTI 1300 > CUC> Greetings
When someone dials the cti is heard this message.
"The system can not complete your call at this time, please try again later"
this is the trace
12:55:21, New Call, CalledId=1300, RedirectingId=1300, Origin=16, Reason=8, CallGuid=E3D1B886EC5B4A9EA42984A6B9889607,[Origin=Unknown],[Reason=Forward Unconditional]
12:55:21, Failsafe
12:55:21, Failsafe: Answer
12:55:21, Failsafe: System Greeting
12:55:21, Failsafe Playing Prompt - /opt/cisco/connection/share/prompts/ESO/G711/CsFailure/FailsafeESO.wav
12:55:28, Failsafe: Hang up
12:55:28, Idle
12:55:28, Idle
12:55:28, Idle
12:55:32, New Call, CalledId=2112, RedirectingId=2112, Origin=16, Reason=4, CallGuid=8E6F13E2852343D3AA0ACD525B70E0DC,[Origin=Unknown],[Reason=Forward No Answer]
12:55:32, Failsafe
12:55:32, Failsafe: Answer
12:55:32, Failsafe: System Greeting
12:55:32, Failsafe Playing Prompt - /opt/cisco/connection/share/prompts/ESO/G711/CsFailure/FailsafeESO.wav
12:55:39, Failsafe: Hang up
12:55:39, Idle
12:55:39, Idle
12:55:39, Idle
12:56:15, New Call, CalledId=2112, RedirectingId=2112, Origin=16, Reason=4, CallGuid=2DD801B08C28426CBAE05F1FB5FD9816,[Origin=Unknown],[Reason=Forward No Answer]
12:56:15, Failsafe
12:56:15, Failsafe: Answer
12:56:15, Failsafe: System Greeting
12:56:15, Failsafe Playing Prompt - /opt/cisco/connection/share/prompts/ESO/G711/CsFailure/FailsafeESO.wav
12:56:18, Failsafe: Hang up
12:56:18, Idle
12:56:18, Idle
12:56:18, Idle
Thank in Advance
Juan
A.M.Mahesh Babu
Are you facing this issue when you try to leave a message or login to mailbox ?
