Cisco unity connection 8.03a & vmware
rbblue234
Hey all,
I'm trying to install unity connection on vmware.  I have provided the Vm with 2gb of ram, 160gb hard drive, and 2v cpu's @ 2.8ghz.
During the install; unity connection is listed under "Products not supported on current hardware".
I took a look at http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html to assist in creating the VM.  Not sure what i must do @ this point...
Any suggestions?
Gajanan Pande
Do you mean, you get that error despite meeting following requirements ?
1. You are using one of the supported server model as mentioned here or here ?
2. You downloaded & are using the OVA template as mentioned here ?
3. Is that the exact error message ( "Products not supported on current hardware".) seen ?
4. What is the ESXi version being used ?
GP.
Gajanan Pande
GP.
well...
I'm have AMD cpu's & curretnly using vmware workstation.
I was able to install call manager 8.0.3 off of the same CD on the same server.  This was going to be the second VM.
I tried the OVA template. (CUC_500_user_v1.0_vmv7) and that got it working.  Not sure what the difference was though.
U rock Gajanan.
