05-03-2017 11:38 PM - edited 03-19-2019 12:24 PM
I'm facing problem on my site. I config auto attendant, working ok. Prompt say
Enter your desire extension or press 0 for operator... 0 is working fine
Problem..
when the user enter extension number . for couple of sec prompt say " wait for transfer e.t.c "then call route to desire extension .
i want to remove this prompt
Solved! Go to Solution.
12-04-2021 03:51 AM
Something is busy out here.
Please check Media resources and trunk configuration between CUCM and CUC.
Hope it helps.
05-04-2017 06:29 AM
On the call handler greeting option there is a checkbox to disable playing this prompt, simply uncheck it.
05-15-2017 09:07 AM
I uncheck this option but no affect . .
prompt say " Sorry all of our representative are busy " then call route to extension .
05-15-2017 09:16 AM
In your initial description you stated call routing is working as expected the only issue is the " wait for transfer e.t.c" message was being played. So, after disabling it the message no longer plays, but now you get another message. The description of the message you posted would imply it is coming in from somewhere other than Unity, i.e. UCCX, Attendant Console, etc. Where is the destination pointing to on CUCM side? Is the original issue with playing " wait for transfer e.t.c" resolved?
05-16-2017 12:36 AM
Sorry i forget to type right message " Sorry all of our representative are busy"
i know "wait for transfer" can be remove by uncheck option. but this " Sorry all of our representative are busy" prompt is killing me . there is no uccx . only cucm 9.1 and cuc 9.1 ..
07-11-2017 06:38 AM
:Hi i solve the issue myself .i put default media recourse in diff group .:)
12-04-2021 03:51 AM
Hope it helps.
