Cisco Unity connection hardware requirement
uxlambad1
I am working on hardware requirements for Cisco Unity connection. I am looking into the OVA template and it says for the hard disk you need is  2x500GB for 20000 users
My question is why we need 2 500GB. Can we do 1TB??
Thanks in advance
Uday
Jaime Valencia
If you mean you want to use 1 HDD 1 TB VS 2 HDDs 500 GB the answer is no, the installer will look for 2 HDDs for the product to be installed if you choose the 10K/20K users VMs.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
