Cisco Unity Connection now supported on UCS-E blades
Anil Verma
Level 5
Level 5
Cisco Unity Connection(UCxn) is now supported to run as a virtual machine on the UCS E blades.
The support is limited to 100 voicemail only users with 8 voice ports.
The requirements and support are documented here - http://docwiki.cisco.com/wiki/Cisco_Unity_Connection_on_UCSE
r.pennington
Level 5
Level 5
that link doesn't work for me, nor does a search for it on the doc wiki site ?
Try this:
Its the same, but there is something embedded in his URL I think, cause it didnt work for me either.
yep that works thanks
