Class of Restrictions (COR) configuration error
Hi guys,
I have configured COR on my C2911 for my CME 8.6 but it didnt work. Based on my configuration below, Phone1 should be able to call only international call but the Phone1 still manage the International call. I dont know what I have missed, but I am following the configuration from Cisco website. It would be much appreciated if any of you guys can help me on this as I am new in Cisco Voice implementation.
dial-peer cor custom
name International
dial-peer cor list InternationalCall
member International
dial-peer voice 900 pots
port 0/0/0:15
description ***Dial-peer_for_InternationalCall***
destination-pattern 900T
corlist outgoing InternationalCall
progress_ind alert enable 8
prefix 00
ephone-dn  1  dual-line
number 3001
corlist incoming InternationalCall
Zul
8 Replies 8
Markus Schneider
Are you saying that ephone-dn 1 can call the international number or that it cannot?  It seems that from your configuration, ephone-dn 1 should be able to reach the international number range.
Hi Markus,
Yes, supposedly ephone-dn 1 can call the international number but it did not work. I have tried the same configuration on different dial peer and still the configuration didnt work. From my configuration, it seems like everything is fine in order for me to allow only ephone-dn 1 can make call to the international number. Do you have any idea why it's not working? Anyway, thanks for replied.
Zul
Does the call work if you remove COR?  Keep in mind that if no COR is applied to a particular ephone-dn and/or dial-peer, the call is supposed to succeed.
Hi Markus,
I just removed the COR on ephone-dn 1, yes it still manage to call international number. There were no changes after I put the COR or remove the COR at ephone-dn 1, international call still can be made. Seriously, I have no idea how to solve it. Tried the same thing at others dial peer and ephone-dn, yet the result still the same.
I think there's a misunderstanding.  If you do NOT have COR configured on any one or both ephone-dn or dial-peer, then you CAN place the call.  If you configure another COR list:
name Local
name International
dial-peer cor list OnlyLocalCall
member Local
port 0/0/0:15
prefix 00
number 3001
corlist incoming OnlyLocalCall
Now ephone-dn 1 should not be able to call the international number, but ephone-dn's without any corlist or InternationalCall corlist should be able to call the international number.
Okay, here is my situation; I have 10 extension numbers, range  between 3001-3010. I wanted to allow only ephone-dn 1 and ephone-dn 2  that can call international number and the rest of the ephone-dn cannot  call the international number. But if I have multiple of dial-peers, do I  need to configure COR for each dial-peer and apply COR at each  ehpone-dn except ephone-dn 1 and 2? correct me If I am wrong again. Below are my latest configuration:
name Local
name Mobile
name 999
dial-peer cor list LocalCallOnly
member Local
member Mobile
member 999
dial-peer cor callLocal
member Local
dial-peer cor callMobile
member Mobile
dial-peer cor list call999
member 999
dial-peer voice 999 pots
corlist outgoing call999
description ***Emergency Calls***
destination-pattern 999.
port 0/3/0:15
forward-digits 3
dial-peer voice 901 pots
corlist outgoing callLocal
description ***Dial-peer_for_LocalCall***
destination-pattern 9[2-9].......
port 0/3/0:15
forward-digits 8
dial-peer voice 902 pots
corlist outgoing callMobile
description ***Dial-peer_for_MobileCall***
destination-pattern 901........
port 0/3/0:15
forward-digits 10
number 3001
ephone-dn  2  dual-line
number 3002
ephone-dn  3  dual-line
number 3003
corlist incoming LocalCallOnly
ephone-dn  4  dual-line
number 3004
From above configuration,  ephone-dn 1 and 2 can call any numbers including international number  while ephone-dn 3 and 4 can call to all numbers except international  number. Does this configuration correct? Hopefully it does. Thanks Markus.
Zul
forgot to add international dial-peer:
translation-profile outgoing out
port 0/3/0:15
prefix 00
For this dial-peer, it has no corlist configured, am I right? and ephone-dn that has no COR configured is able to call international number. I am confused here, what about others call? Does this ephone-dn with no COR configured is able to make call to any number? or only can call the international number?
Thanks.
Take a look at this tech tip:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
There's a nice table near the bottom that illustrates what happens with/without corlist configurations.  In essence, if there is no COR configured, it can call anything/be called by anything.
