Click to Call 64-bits return error from GetDevices
fodermat
Hi there,
We are testing Click to Call widget in our lab, the 32-bits version works fine on a Win7 32-bit laptop, but we are getting an error on the 64-bits version on a Win7 Professional 64-bits.
When we configure the user credentials and Webdialer service Hostname, no error is prompted, but the configuration is not saved properly.
In the log file we get the following error (translated from Spanish):
INFO  - return error from GetDevices - URI not valid: can not analyze hostname.
When testing with a wrong password, we are prompted with an error advising to review username/password, so we understand the connection is established with Webdialer and authentication works fine. Not sure what URI it speaks of.
Where to look at to move further on this?
Thanks!
Javi
Md Hasan
Hi Hasan,
Thanks for your reply.
Unfortunately we are already using the latest version (8-0-2540) :-(
Javi
Hi Javi,
If the latest ver is showing the symptom, please open up a TAC case to have it looked at.
