Click to Call Dialing Rules
rcustersp
I am having trouble understanding dialing rules. Here we have to dial 8 to get an outside line, so I need to set a rule that 8 gets added to every number. Does the 8 go in the Number Begins With field? Then how does it know which numbers to apply this to?
Thanks!
Aaron Harrison
You match the string that the CTI app (CUPC< click to dial, whatever) will have input to it. So match the numbers in 'whatever you are dialing from' (e.g outlook, web pages etc). You would then insert a prefix of 8 as part of the dialing rule.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Tommer Catlin
you can check out this table, its a good start.
http://www.cisco.com/en/US/docs/voice_ip_comm/cupa/click_to_call/7.0/english/install/guide/C2C2chapter.html
Also, when you add in the App Rules, it will take a little time for the CUPS to update its own tables. (if you are using the rules for this)
