CM 4.0.5 Speed Dials
helpdeskhobaho
Some users have problem with adding speed dials under the services button. One user can add 3 numbers as speed dial. When adding the 4th speed dial nothing happens. One users has the same problem after adding 9 users and adding the 10th. Has anyone an idea?
lindborg
You'll probably want to ask this over on the IP Telephony forum - this forum is for questions on cisco Unity (unified messaging platform).
mparekh
Level 3
Level 3
Verify that the 4th speed dial entered is not using Abbreviated Dialing.
