06-14-2015 05:38 PM - edited 03-19-2019 09:42 AM
I am running CME version 8.6
When my customer is trying to dial a long distance number, lets say for this example the number is 915556667777, it randomly selects dial-peer 130 or 150. When it matches 130 it prefixes 727 and the call then is routed to 7279155566. Below is snippets from my configuration. If I change dial-peer 130 from destination-pattern 9T to destination-pattern 9[2-9]T would that fix the issue from matching 130? Any help would be greatly appreciated.
*************dial-peer snippet*************
dial-peer voice 130 pots
trunkgroup FXO_Trunk
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
forward-digits 7
prefix 727
no sip-register
dial-peer voice 150 pots
description ***North American 10-Digit Long Distance***
destination-pattern 91[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 160 pots
destination-pattern 9[2-9].........
forward-digits all
no sip-register
*************voice translation snippet*************
voice translation-rule 1000
rule 1 /^9/ //
voice translation-rule 1100
rule 1 /^...$/ /7279381516/
voice translation-rule 1500
rule 1 /^6/ //
voice translation-profile OUTGOING_TRANSLATION_ALL
translate calling 1100
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1000
voice translation-profile Transfer_to_Voicemail_Profile
translate redirect-called 1500
*************telephony-service snippet*************
telephony-service
sdspfarm units 1
sdspfarm tag 1 xxxxx
group 1
ip source-address x.x.x.x port 2000
url services http://x.x.x.x/voiceview/common/login.do
url authentication http://x.x.x.x/voiceview/authentication/authenticate.do
internal-call moh-group 1
pin xxxxx override
fxo hook-flash
max-ephones 58
max-dn 192
max-redirect 20
auto assign 20 to 60
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
timeouts busy 5
timeouts ringing 30
load 7914 S00105000400.sbn
load 7912 CP7912080004SCCP080108A.sbin
load 7960-7940 P0030801SR02.loads
time-zone 12
voicemail 200
max-conferences 3 gain -6
call-forward pattern .T
hunt-group logout HLog
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
transfer-pattern 9.T
transfer-pattern 6.... blind
transfer-pattern 6... blind
secondary-dialtone 9
login timeout 60
fac standard
06-14-2015 06:20 PM
It means you have an overlapping dial-peer. You can control this by having a specific destination-pattern which you already did. Other way is by putting "preference" command on each dial-peer. By default all dial-peers have preference 0.
Have a look at this documentation:
http://www.cisco.com/c/en/us/td/docs/ios/12_2/voice/configuration/guide/fvvfax_c/vvfpeers.html#wp1244361
06-14-2015 06:29 PM
But would my solution I provided above work?
06-14-2015 06:53 PM
No, it won't match dial-peer 130 but will match dial-peer 150. Use this command to test which dial-peer is matching - "show dialplan number XXXX".
I'd suggest to have separate dial-peers for local, national, international, emergency, toll-free, etc numbers. This is to avoid the issue you are experiencing.
06-14-2015 06:59 PM
I want it to match 150 so that is a good thing and thank you for the command. I will try that.
Also I do have dial-peers for national, international, emergency but didn't list them here. Only listed the dial peers that were causing the issue
