CME strange !
Jonn cos
Level 4
Level 4
Hi all experts.
I have a very simply topology,
IPC-1--------------------------R1----------------------------------------------R2----------------------------------IPC-2
          SCCP (g711)                 default dial peer voip                         SCCP(g711)
                                                    (codec=g729)
(IPC stands for IP communicator)
When i make the call from IPC-1 to IPC-2, the call is successful !! why ? i am testing this on dynamips and as per my knowledge R1 has to transcode from G711 to g729 so the call should fail (since dynamips doesnt use DSPs),
I am really missing something big here. Pls guide me pls
paolo bevilacqua
Phones also support g.729, so check with which codec the call is established.
Dear Sir,
I cant paste the results here, since i built this scenario at my home. But i checked yesterday and the codec was g729. So are you saying that transcoding is not required because phones also support g729 ?
Rob Huffman
Hi John,
Paolo is most correct (+5"P")
Here is an example for IPC;
Network Features
Cisco IP Communicator includes the following network features:
● G.722 wideband, G.711a, G.711ų, iLBC, G.729a, and G.729ab audio codecs
http://www.singlepointoc.com/products/cisco/docs_voice/data_sheet_c78-505261.pdf
Cheers!
Rob
