collaboration PCD migrate question!
shu shen
Hi experts
I have encountered a CUCM migration issue.
When I migrated CUCM 8.6 to 11.5 through the PCD program, CUCM SUB reported an error during the installation process.
Prompt "Invalid time zone Asia/Chongqing".
Ask the experts, how to solve this problem?
Jaime Valencia
I'd suggest you temporarily move the timezone from your server to other option, it might be the option no longer exists in the target release, or was re-named.
Another option might be that you installed a non NANP dial plan, and that's causing a problem during the migration.
Further details would need to be reviewed in the dump file.
java
if this helps, please rate
Jaime Valencia
java
Thank you for your reply, but during the migration process, the cucm pub was successfully installed. No error was reported. The pub and sub versions are the same, both are 11.5.
I modified the timezone of CUCM 8.6 and re-created a migration. The installation was successful! thank you for your help.
