Configuration Validation with [PUBLISHER] Failed.
devils_advocate
Level 7
Level 7
I am trying to rebuild our CUPS environment, our old VM's are shut down and I am building two new ones with the same IP addresses
I completely deleted both nodes from CUCM, both from System > Server and also the Presence Redundancy Group.
I then added the CUPS Publisher Server to CUCM BEFORE I started the new install.
It just errors with ' Configuration Validation with [PUBLISHER] Failed.'
The security password is correct, as is the hostname and IP.
Its driving me up the wall, it shouldn't be this difficult.
I even deleted CUPS from CUCM again, trashed the install and started again...same error!
Followed the steps to the letter and I get the same error!
I am going to have to log a call with TAC.
I even tried building a new CUPS Pub with an unused IP address and it still errors so something is not right.
The security password is correct as I have double checked it.
I am having the same issue on lab 11 install. Did you get a solution?
Nope
I have spent several days with TAC now, rebuilt the CUPS Pub several times and I can't get past this error!
They are now saying to reset the security password for the CUCM Pub but I know the one I am inputting is correct, I am going to do it just to satisfy them.
I literally have no idea why its not working....
