Configure SIP trunk
Pete720
Hello everyone,
    I'm working on a class project on voip and have a little knowledge on it.
    I'm using CUCM 8.6. I setup HQ with MGCP gateway. The gateway is connected and working. I need to setup SIP voice gateway for Branch.  How do I configure SIP gateway? Do I have to do any configuration in Branch router or everything is done through CUCM?
Any help is greatly appreciated.
Pete720
Also what do i have to do to configure SRST in Branch with SIP gateway?
CUCM can do SIP trunking, it depends on what you need.
Nothing related to a SIP trunk on ISR is done via CUCM, it's all CLI, you can just search "SIP trunk configuration" on cisco.com to get examples, same for SRST, "SRST configuration" on cisco.com
java
if this helps, please rate
