Configure the priority feature for calls on a busy line
Amek
Hello dear all
My concern is the following: I want to configure the functionality to break into an ongoing communication by emergency. I describe a small scenario:
-I have three Cisco IP Phones A, B and C
-A and B are in communication
-I would like to give priority to C to enter their communication for an emergency.
I have a full Cisco phone system with a CUCM 12.5 server
Thank you for helping me.
7 Replies 7
 Hi Andrea Lippa thanks for your answer,
But unfortunately I have already configured the Barge but it didn't solve my problem.
Jaime Valencia
Review the MLPP feature and see if that is what you're looking for.
java
if this helps, please rate
Hi Jaime
I proceeded to set up the MLPP protocol and during the configuration I checked the box Make this the Default Resource Priority Namespace Network Domain .
This prevents outgoing calls through the mobile gateway (GSM) as you can see in the screenshots
Unfortunately, I can't uncheck the box to cancel the configuration.
Thanks for your help
Amek
Thank you Jaime Valencia for your response,
I will configure and test the MLPP to see if it solves my problem and get back to you. Thanks
Amek
PTS
Hi Amek,
If you are open to Cisco 3rd party solutions then the above required can be fulfilled via a custom solution for CUCM.
For more details you can write to info@parsec-tech.com
www.parsec-tech.com
