ConnectionId
bluesea2010
Level 5
Level 5
What is conenctionID and how its  generated ?
if 5500 calling a  National number  outside , how we can correlate 5500 called   2xxxxx outside  from cisco 2821 voice router logs ?
Mohammed Khan
Check below link section "Understanding Cisco IOS CCAPI Debugs"
https://books.google.co.in/books?id=YcCjKsssklIC&pg=PA196&lpg=PA196&dq=%22Understanding+Cisco+IOS+CCAPI+Debugs%22&source=bl&ots=ZY34ooOJKB&sig=691gTiL1Epg1XE3oKg9pht-9jjo&hl=en&sa=X&ved=0ahUKEwirgoyjtIXQAhVFLo8KHedBCJYQ6AEIHTAA#v=onepage&q=%22Understanding%20Cisco%20IOS%20CCAPI%20Debugs%22&f=false
ConnectionId is same as GUID
Thanks for the link ,But it does not say much about call legs ?
My question how we can correlate the call legs from the syslogs .
As per the  document connection id is  "A locally-significant hexadecimal string of up to 32 characters that identifies a connection within an endpoint. This parameter is locally significant only to each endpoint."
here the endpoint  means a phone ?
What does it mean by  a connection within an endpoint
