11-10-2006 11:19 AM - edited 03-18-2019 06:36 PM
Hello there! I'm having some problem configuring CTI Gateway on CUPS: First, I follow the CUPS Deployment Guide to create an application user CtiGW on the CUPS, but the troubleshooter reports that there's a mismatch of CTI Gateway userid/pwd btw CUPS and CCM, I'm confused, does that mean I need to create the user CtiGW on CCM instead of CUPS(which BTW I did but doesn't help)? Second, in Application -> CTI Gateway -> Settings, when I try to turn on the application and specify the user CtiGW, got error message as follow:
Update failed. java.sql.SQLException: Could not insert new row - duplicate value in a UNIQUE INDEX column.
Any ideas/suggestions are much appreciated, thank you very much for your help!!
03-27-2007 04:06 AM
I know its been a few months, but did you ever find a solution to this issue? I am running into the same problem.
Thanks!
03-27-2007 10:50 AM
The answer is to not manually create the CtiGW user on CUPS, it will be automatically created. I hope this helps someone in the future.
05-22-2007 05:32 PM
Great tip-thanks for the post! The documentation is wrong on this one.
