Showing results forĀ
Search instead forĀ
Did you mean:Ā
CTI Route Point not registering
voipeee
Level 3
Level 3
I have created CTI Route Point and it is not registering:
I have added CTI RP in Jatapi App user.
Standard CTI Enabled Group/Role is done.
I am using it for System call handler(CUC).
CTI services is enabled in CUCM.
I also restarted CUC.
Any suggestions?
Jaime Valencia
CTI RP DO NOT register, unless you're actually using them with a TAPI/JTAPI application
java
if this helps, please rate
