09-13-2016 07:08 AM - edited 03-19-2019 11:35 AM
We recently started using Cisco Unified Attendant Console Standard and it is working pretty well. One issue though:
If you have several parked calls it is easy to forget why they were parked. Usually they are parked waiting for someone to become available but if 4 calls are parked how does one know who they are waiting for. Same thinking if calls are on hold.
Is there a way to flag a parked or on hold call as 'waiting for Bill' ?
Thanks.
Solved! Go to Solution.
08-21-2017 04:25 PM
Michael,
There is a Parked Calls Pane that shows information about the call including from, for whom, routing and parked by.
See here for more information (under Parked Calls Pane):
08-21-2017 04:25 PM
Michael,
