10-04-2010 01:29 AM - edited 03-19-2019 01:41 AM
I have a new CUBAC 8 with CUPS 8 and CUCM 8
I have configued the CUPS section on CUBAC and when I do the test connection it is successful
I have added the CUBAC server to the incoming/outgoing ACL on CUPS
However I do not have phone / line presence information on CUBAC
Have I missed anything?
Many Thanks
10-04-2010 12:32 PM
Best way to do fault isolation is to test the phone presence with a CUPC client.
If you can see phone presence on CUPC client, the problem is on CUBAC/CUPS integration.
Otherwise, the problem is on CUPS/CUCM integration. You might want to check capability assignments, line apperance assogication, etc.
Michael
10-04-2010 12:44 PM
Micahel,
CUPC client appears ok and can see presence
There does not appear much to do on the CUBAC to CUPS integration.
What would I check?
10-04-2010 12:47 PM
As far as I know, this part of feature is very buggy on previous version of CUBAC, such as shared-line, multi-line support.
You'd better check with TAC to make sure you're not hitting those bugs.
Michael
10-05-2010 03:52 AM
Michael,
Whilst I thought my CUCM - CUPS integration was fine I am now not sure - It is not fiully deployed yet
I have 2 test users on CUPC
they can each see their presence and we can see each others fine.
I am using extension mobililiy
However when I go to the presence viewer
I put my user id - it basically comes up with line presence status unknown.
Each UDP line has the user association
each user has standard cti enabled
each user has CUP/CUPS capabilities in licencing
What am I missing
10-05-2010 05:26 AM
Availability and phone presence are two different features.
In your very first post, you said "I do not have phone / line presence information on CUBAC"
Were you able to see "phone / line presence" from CUPC clients?
Michael
10-05-2010 05:31 AM
Michael,
I only have two users working on CUPC at present
However if I log onto CUPC and also log onto phone I can see my presence status - on hook etc
Also can see the other user's presence status
However If I go to presence viewer and do a presence view based on my id against the other id I have no presence information for the other persons line.
does this make sense?
10-05-2010 06:13 AM
Two things on the CUBAC side:
Also, loading presence can take a bit after performing a search; give it a bit. On the phone or in a meeting are displayed as a red 'Busy' state instead of the typical yellow color from CUPC.
10-05-2010 07:15 AM
Let's do this step by step.
Assuming you have two users - user A and B.
1) If you logged into CUPC as user A and add user B to the contact list, would you be able to see user B's status as "Available" (green)?
2) If user B picks up his phone, from user A's CUPC, would you be able to see user B's status change to "On-The-Phone" (yellow)?
Thanks!
Michael
10-07-2010 04:08 AM
Hi Michael,
I have two users on CUPC and each user can see availaiblity and presence information of each other - These users are EM users
So yes user A picks up phone and user B sees on phone, vice versa
However in the presence viewer I do not see presence information.
So I think my SIP trunk is ok, but how come the presence viewer does not show this information?
10-07-2010 12:55 PM
Anderew,
We are having the exact same problem with CUPS 8.02, only we are using Arc's Enterprise console. All our CUPS clients are working fine, but the Arc Console shows all users as "unknown".
I just got off the phone with an Arc engineer. He said that Arc pulls the information differently than the CUPS client and anything you see in the Presence Viewer on the CUPS server is what you will see on the Arc Console. We were a little skeptical of this at first, but he pointed out that CUPS client custom status messages don't show up in the Presence Viewer, they just show as "busy". That's why the Arc Console doesn't display custom status messages.
Also, TAC told us there is a problem with the Presence Viewer in CUPS 8 - until now, weren't sure if that had anything to do with it.
10-07-2010 01:08 PM
Thanks for the response.
I have started rolling out CUPC users today and presence/availability all works fine on CUPC
But the presence viewer does not and your comment from TAC explains this.
I like you do not have presence in Attendant console.
Was about to launch TAC case - Do you already have one?
Would be most interested to learn of the fix.
I am thinking that Version 8 of the entire UC range is very buggy
I have raised more tac cases on this UC 8 delpoyment than I ever had to on previous releases.
Andrew
10-08-2010 09:52 AM
TAC confirmed this a bug in Presence 8. It only happens when using the UPN login names (bob@domain.com), which is how our customer is setup. If you can change Call Manager to use the Sam Account Name instead of the User Principal Name for user for the Active Directory integration, you should be able to get this working. Our customer has to use UPN because they have two domains in AD.
We are waiting to hear from TAC about the timeline for a bug fix.
09-23-2011 06:56 PM
Bug ID please? I need to get this out of the way so I have something official to point to the customer. Thanks.
10-21-2010 09:20 AM
Did you ever find anything with this? I have a CUBAC and CUCM 8.x. I have about 100 phones right now or users in the directory. I can see on the left side the I have most phones showing on/off hook status. But a few, show a red "X" on the phone. Correct me if Im wrong here, but for the Presence indicator on the far right of the AC client to show Green/Red/Yellow, we need to have CUPS integrated. Correct?
