cube and cucm intigration with sip trunk from isp
sandysp4u
Hello Friends,
I am trying to setup cube router i tried everything but somehow it's not working can I get little help from helpful people around here.
my cube ip is 172.16.8.1
my cucm ip is 172.16.20.11
ISP gateway ip 100.64.77.89
ISP SBC ip100.64.216.4
gateway and sbc is reachable to me from my router
bellow is my configuration
voice service voip
ip address trusted list
ipv4 100.64.77.89
ipv4 100.64.216.4
ipv4 172.16.20.11
ipv4 172.16.20.9
mode border-element license capacity 20
media bulk-stats
allow-connections sip to sip sip
header-passing
error-passthru
early-offer forced
midcall-signaling passthru
voice class uri 1000 sip
host 172.16.20.11
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice translation-rule 100
rule 1 /.*/ /826/
voice translation-profile TP100
translate called 100
dial-peer voice 200 voip
description ***Cube to Cucm ***
translation-profile incoming TP100
session protocol sipv2
incoming called-number 02632350100
codec transparent
no vad
dial-peer voice 100 voip
description ***Cube to Cucm826 ***
destination-pattern 826
session target ipv4:172.16.20.11
codec transparent
I am also attaching my cucm config ss of trunk and dial pattern
What else i need to do to make this sip work ?????
Thanks in advance
Knowing that it might be hard to understand all the things mentioned in my prior response I took the time to re-work your configuration to suggest what I would have configured for your described setup. The configuration is based on your previous shared configurations.
voice service voip
  no ipv4 100.64.77.89
  ipv4 100.64.216.4
  ipv4 172.16.20.11
  ipv4 172.16.20.9
 media bulk-stats
 sip
  header-passing
  error-passthru
  early-offer forced
no voice class uri 1000 sip
no voice class uri cumctocube sip ! voice class uri CUCM sip host ipv4:172.16.20.11 host ipv4:172.16.20.9 ! voice class uri JIO sip host ipv4:100.64.216.4 ! voice class codec 1 codec preference 1 g711ulaw codec preference 2 g711alaw ! voice class e164-pattern-map 1 description E164 Pattern Map for CUCM numbers e164 894 e164 826 ! voice class e164-pattern-map 200 description E164 Pattern Map for PSTN numbers e164 +T ! voice class server-group 1 ipv4 172.16.20.11 preference 1 ipv4 172.16.20.9 preference 2 ! voice class server-group 200 ipv4 100.64.216.4 ! voice class sip-options-keepalive 1 ! no voice translation-rule 100 no voice translation-rule 101 no voice translation-rule 200 ! voice translation-rule 100 rule 1 /.*101$/ /894/ rule 2 /.*100$/ /826/ ! voice translation-rule 200 rule 1 /^894$/ /+912632350101/ rule 2 /^826$/ /+912632350100/ ! voice translation-rule 110 rule 1 /^000\(.*\)/ /+\1/
rule 2 /^0\(.*\)/ /+91\1/ ! no voice translation-profile 101 no voice translation-profile TP100 ! voice translation-profile PSTN-IN translate called 100 ! voice translation-profile PSTN-OUT translate calling 200 ! voice translation-profile CUBE-IN translate called 110 ! no dial-peer voice 101 voip no dial-peer voice 201 voip no dial-peer voice 400 voip no dial-peer voice 300 voip no dial-peer voice 200 voip no dial-peer voice 100 voip ! dial-peer voice 1000 voip description ****Inbound CUCM to Cube**** translation-profile incoming CUBE-IN session protocol sipv2 incoming uri via CUCM voice-class sip bind control source-interface GigabitEthernet0/0/0 voice-class sip bind media source-interface GigabitEthernet0/0/0 dtmf-relay rtp-nte sip-kpml voice-class codec 1 no vad ! dial-peer voice 1010 voip description ***Outbound Cube to CUCM*** destination e164-pattern-map 1 session protocol sipv2 session server-group 1 voice-class sip options-keepalive profile 1 voice-class sip bind control source-interface GigabitEthernet0/0/0 voice-class sip bind media source-interface GigabitEthernet0/0/0 dtmf-relay rtp-nte sip-kpml voice-class codec 1 no vad ! dial-peer voice 100 voip description ***Inbound JIO to Cube*** translation-profile incoming PSTN-IN session protocol sipv2 incoming uri via JIO voice-class sip bind control source-interface GigabitEthernet0/1/1 voice-class sip bind media source-interface GigabitEthernet0/1/1 dtmf-relay rtp-nte voice-class codec 1 no vad ! dial-peer voice 110 voip description ***Outbound Cube to JIO**** translation-profile outgoing PSTN-OUT destination e164-pattern-map 200 session protocol sipv2 session server-group 200 voice-class sip options-keepalive profile 1 voice-class sip bind control source-interface GigabitEthernet0/1/1 voice-class sip bind media source-interface GigabitEthernet0/1/1 dtmf-relay rtp-nte voice-class codec 1 no vad !
There might be part(s) that needs a little polishing, but over all this should be a working solution based on the information you have provided. Try it out and let us know how it went.
Response Signature
31 Replies 31
collinks2
Level 5
Level 5
i cant view the sip registrar in the output of the config.
cube(config)# sip-ua
Cube(config-sip-ua)# registrar 1 dns:example1.com expires 180
example1.com is the dns of your sip provider
cube (config-sip-ua)#sip server ipv4:the ip of the sip server
who is your sip provider?
sip provider is jio i tried adding that command but its not taking it
  1. post the command here after you entered it in the router so i can take a look.
Meanwhile, did your sip provider provide credentials to you.
Like Roger pointed out,there is no outgoing dial-peer from cube to the isp. create an outgoing dial-peer with the session target: ipv4: ip address of your sip provider
Sip registrar is an option unless your sip provider wants you to authenticate.
ok i tried ipv4: then adding address and command was accepted
it was like sip registrar ipv4:xxxx
i also changed the dial peer please find the latest config now i am able to receive the call from out to in but in to out is not working.
DungriRouter#show run | sec voice
voice service voip
ipv4 100.64.77.89
ipv4 100.64.216.4
ipv4 172.16.20.11
ipv4 172.16.20.9
media bulk-stats
sip
header-passing
error-passthru
early-offer forced
host 172.16.20.11
voice class codec 1
rule 1 /.*/ /826/
description ***ISP to CUCM826***
incoming called-number +912632350100
dtmf-relay rtp-nte
codec g711ulaw
no vad
codec g711ulaw
no vad
description ***Outbound Cube to JIO ****
destination-pattern 912632350100
session target ipv4:100.64.216.4
dtmf-relay rtp-nte
codec g711ulaw
no vad
description ****Inbound Cucm to Cube ****
dtmf-relay rtp-nte
codec g711ulaw
no vad
DungriRouter#
AFAICT you have no dial peer(s) in the direction of your service provider. Without this your not going to have any SBC functionality in your CUBE. For more details on how to setup an SBC please see this document.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/sip/configuration/15-mt/sip-config-15-mt-book.html
For details of how dial peers works in general please see this document.
https://www.cisco.com/c/en/us/support/docs/voice/ip-telephony-voice-over-ip-voip/211306-In-Depth-Explanation-of-Cisco-IOS-and-IO.html
Response Signature
i have configured dial peers please check the bellow config it's still not working
voice service voip
ipv4 100.64.77.89
ipv4 100.64.216.4
ipv4 172.16.20.11
ipv4 172.16.20.9
media bulk-stats
sip
header-passing
error-passthru
early-offer forced
host 172.16.20.11
voice class codec 1
rule 1 /.*/ /826/
dtmf-relay rtp-nte
codec g711ulaw
no vad
codec g711ulaw
no vad
dtmf-relay rtp-nte
codec g711ulaw
no vad
dtmf-relay rtp-nte
codec g711ulaw
no vad
The destination number on your outbound dial peer to your service provider does not look correct.
Check this and modify it to match how you send outbound called number from CM to your voice gateway and then onwards to your service provider.
Response Signature
i am trying to understand it but not much of success i have changed it to this now
destination-pattern +912632350100
dtmf-relay rtp-nte
codec g711ulaw
no vad
Isn’t that destination number, +912632350100, an inbound number, ie it’s part of your assigned DID number range? You should have your destination pattern set to match the outbound called number(s), not inbound DID number(s). For example if you use +E.164 formatted called number you could use +T as the destination pattern or if you use a breakout code such as 0 or 9 you could use 0T or 9T.
Apart from this I would recommend that you use information in the via header for inbound dial peer matching. This gives you a more deterministic match for your inbound dial peers, one for the call leg from CM and another for the call leg from your service provider. For details on this see the second link that I shared earlier.
Response Signature
ok sir if i place a dot in destination pattern will it work i tried that also but it doesn't seem working. i will try to via hader and will let you know
I would not recommend you to use a dot as the destination pattern as that’s a to wide match statement. What is your match statement in CM for the outbound calls on your route pattern(s)?
Response Signature
in CUCM the match statemetn is 0.xxxxxxxxxx
i am using 0 to make user start the call for outbound calls and then he/she can dial the number he/she wants to reach
Based on that I would recommend you to use 0T as the destination pattern on the outbound dial peer to your service provider and use a voice translation profile to remove the leading 0 (zero). To do so make sure that you don’t drop the zero on the route pattern in CM when sending the calls to the gateway.
For details on how to use voice translation profile and rules see this document.
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/61083-voice-transla-rules.html
Response Signature
Hello
Thanks for all the help you are giving.
my service provider wants me to send request in the bellow format
Outgoing Calls:
Sample Customer Outbound call, SIP invite received from Customer PBX to E_SBC.
To: <sip:+91(b-party-number)@SBC end IP>
Contact: <sip:+91(did or pilot)@WAN IP:5060>
