cube and cucm intigration with sip trunk from isp
sandysp4u
Hello Friends,
I am trying to setup cube router i tried everything but somehow it's not working can I get little help from helpful people around here.
my cube ip is 172.16.8.1
my cucm ip is 172.16.20.11
ISP gateway ip 100.64.77.89
ISP SBC ip100.64.216.4
gateway and sbc is reachable to me from my router
bellow is my configuration
voice service voip
ip address trusted list
ipv4 100.64.77.89
ipv4 100.64.216.4
ipv4 172.16.20.11
ipv4 172.16.20.9
mode border-element license capacity 20
media bulk-stats
allow-connections sip to sip sip
header-passing
error-passthru
early-offer forced
midcall-signaling passthru
voice class uri 1000 sip
host 172.16.20.11
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice translation-rule 100
rule 1 /.*/ /826/
voice translation-profile TP100
translate called 100
dial-peer voice 200 voip
description ***Cube to Cucm ***
translation-profile incoming TP100
session protocol sipv2
incoming called-number 02632350100
codec transparent
no vad
dial-peer voice 100 voip
description ***Cube to Cucm826 ***
destination-pattern 826
session target ipv4:172.16.20.11
codec transparent
I am also attaching my cucm config ss of trunk and dial pattern
What else i need to do to make this sip work ?????
Thanks in advance
31 Replies 31
Hi Colin,
Thanks for helping me out please find the link of pastebin showing the output of debug
https://pastebin.com/PB3KXmh1
you issued debug ccsip messages instead of debug voice ccapi inout
i found this error which Roger pointed outSIP/Info/info/2048/sipSPICheckIpip: VOIP dialpeer (peer=0x558D4333C304) found for sip_user: +912632350100 Dec 24 09:35:04.583: //-1/9BDC79E48102/SIP/Info/info/2048/sipSPICheckAssertedIdConfig:Dialpeer match is not yet done.
There is no dial-peer match for +912632350100
check the outgoing dial-peer and modif the settings.
Also paste the output of debug voice ccapi inout
