CUBE functionality and licenses - ISR 4331
themizzz21
We want to enable the border element mode on an ISR 4331
cisco IOS XE Software, Version 16.06.09
Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Ve rsion 16.6.9, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Wed 24-Feb-21 09:21 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Poseidonos_VG uptime is 1 day, 9 hours, 9 minutes
Uptime for this control processor is 1 day, 9 hours, 11 minutes
System returned to ROM by Reload Command at 07:08:54 EEDST Tue Apr 19 2022
System restarted at 07:14:41 EEDST Tue Apr 19 2022
System image file is "bootflash:isr4300-universalk9.16.06.09.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 uck9 Permanent uck9
securityk9 None None None
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4331/K9 (1RU) processor with 1795969K/6147K bytes of memory.
Do we need licenses for that?
Thank you.
Yes Cube is a licensed feature in IOS.
Response Signature
Cube feature require license. You are on a version which Smart licensing is not mandatory. if you are moving to IOS XE 16.10.1a + you need to have the CUBE licenses available on your smart account.
With your version you use Cube RTU.
Response Signature
