CUBE Guide
omarahmed
hello i need you r help to give a guide for config cube a
2 Accepted Solutions
Vaijanath Sonvane
The translation rules are not mandatory but as @Jaime Valencia mentioned it depends on your needs. For example:
  • When you make outbound calls, which number you want to display as your caller ID, main office number of individual DID
  • When you receive inbound calls, in most cases service provider sends called number in E.164 format. If your extensions are 4 or 5 digits then you need to configure translations to route your calls.
There are many different scenarios where you need to configure translation rules.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
https://www.cisco.com/c/en/us/support/unified-communications/unified-border-element/products-installation-and-configuration-guides-list.html
i have another question does the translation rules it's mandatory i mean we must configure it if you can explain to me
thank you
Translation rules depend on your needs, you need to determine if you need them or not.
There's plenty of CUBE material on Cisco Live Sessions that you can review.
java
if this helps, please rate
