CUBE Media Forking - call direction always the same
cistera.com
I have a very basic lab setup for media forking to our apps from a CUBE.  CUCM with phones and CUBE as gateway with route pattern set to cube for another set of phones connected to a CME.  Route patterns and media forking is working, but it is not swapping the caller ID properly (media-index="0", and media-index="1").
The docs say that whichever (in/out bound) dial peer the forking profile is set to determines the perceived direction of the call, but if I cann both directions, the indexes never change.  If the CUBEs dialpeer toward the CME has the recorder profile set on it, the CME phone is always index 0, and vica-versa.  Not sure where to go from here.
CUBEs config ::
voice service voip
 ip address trusted list
  ipv4 192.168.15.18 255.255.255.255
  ipv4 192.168.9.254 255.255.255.255
  ipv4 192.168.9.253 255.255.255.255
  ipv4 192.168.15.25 255.255.255.255
 address-hiding
 mode border-element
 allow-connections sip to sip
media profile recorder 10000
 media-recording 20 30
media class 3
 recorder profile 10000
media service
dial-peer voice 20 voip
 description Dial-Peer -- 15.18
 destination-pattern 7778
 session protocol sipv2
 session target ipv4:192.168.15.19 --> (our server)
 session transport tcp
dial-peer voice 1 voip
 description To CUCM -- 9.14
 destination-pattern 5...
 session target ipv4:192.168.9.14 --> CUCM 10.5 with 5034 DN
 codec g711ulaw
 no vad
dial-peer voice 2 voip
 description In from CME(s)
 destination-pattern 100.
 session target ipv4:192.168.9.254 --> CME 10.5 with DN 1000
 media-class 3
 codec g711ulaw
 no vad
CME Config ::
voice service voip
 sip
dial-peer voice 10 voip
 description to CUBE -- 9.252
 session target ipv4:192.168.9.252 --> CUBE
 codec g711ulaw
 no vad
With the cube's dial-peers this way, DN 1000 is always stream0, with the recording profile moved to dial-peer 1, then 5034 is always stream0 (no matter which direction the call is made from).
Any ideas?  Thanks!
-Greg Oliver
0 Replies 0
