CUBE: Passing parameters between SIP Responses and Request
aalejo
Level 5
Level 5
Dear Community
It is possible to pass parameters between sip responses and requests on same transaction: For example a redirected call comes in (SIP Request) and i would like to pass redirection number to the Response (SIP response) on this transaction.
Thanks!
15 Replies 15
b.winter
I did not "simplify" it for you: i simplified to remove everything and place a hard example. It was not an irony was simply an statement.
I did not say "i have done a lot of copy-list", i said i said "that i have use on several occasions" which is quite different: Don't change my words.
That i have use copy-list on several occasions does not mean that i know the solution: That's why i posted. Maybe is not even possible. Not everything is possible using copy-list and sip profiles or even w current Cisco tools on routers.
If you don't know the answer, that's OK, I don't know the answer neither. Not hard feelings
