10-02-2012 06:49 AM - edited 03-19-2019 05:38 AM
Is it possible to change the system own default greeting? Or simpler... replacing the "cisco girls" waves.
Example:
<<My Text>> Voicemail Box Owner Name <<My Text>>
Thx for help
Phil
Solved! Go to Solution.
10-02-2012 07:24 AM
Hi Phil,
The changes that you would like to make are part of the
"System prompts"and changing them is not supported. Here is the reference;
The prompts that come with the Cisco Unity Connection system are played in different combinations in multiple places in the phone conversation.
While changing, replacing, and deleting prompts is not supported and can cause system errors, you can specify the default language in which system prompts are played to all Connection users and callers
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag120.html
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
10-02-2012 07:24 AM
Hi Phil,
Cheers!
Rob
10-03-2012 12:42 AM
Hi Rob
Thanks for help.
Is there an other way to a Corporate Desige Greeting by default, when I create a new vm-box?
Thx Phil
