CUC Call Handler
Leonardo Santana
I have a number that redirect to CUC Call Handler plays a Welcome message and redirects to a hunt Pilot at CUCM.
This hunt if the extensions do not answers CUCM need to redirect to a voicemail of this extensions, how i do that using distributions lists?
I configured but is the voicemail is redirecting to the default greeting of CUC.
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
2 Accepted Solutions
Deepak Mehta
You can run port number analyser to check what is the redirecting DN is hitting the unity voicemail .This will give us an idea why it is going to default greeting.
Also you can try to give wild card mask of whatever length DN you are using inside voice mail profile and see if that works.thanks
Good answer Deepak Mehta, tks.
Following the link for download.
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
PS: Do not forget to allow the *.exe program in (C:\Program Files (x86)\Cisco Systems\Unity Connection\Remote Port Status Monitor) in windows firewall.
Have a nice day.
Daniel
Daniel Sobrinho
Deepak Mehta
Have a nice day.
Daniel
Daniel Sobrinho
Hello Deepak,
We created a fowarding rule and now is hitting the voicemail greetings.
Leonardo Santana
Leonardo Santana
