CUC - Question
Quintin.Mayo
Level 3
Level 3
We have a customer that is asking if CUCM platform uses native e-mail functionality below.  I believe the answer is "no" but wanting to confirm before getting back to the customer. Please advise.
I'm following up on a topic around native e-mail functionality (*further explanation below) within some of the apps/tools we use. This functionality should not be enabled if someone is using a non-business e-mail application. This is to prevent a non-employee from getting an e-mail that provides the capability to connect into our business (a link in the e-mail for example). If disabling this feature would cause problems, please let me know so we can talk further about why we're looking to disable this functionality from our tools/apps.
Thank you.
Could you let me know if the tool listed below, uses native e-mail?
If native e-mail functionality is used, can you confirm that capability is removed/disabled, or only the business e-mails would receive any native e-mail that is sent?
Apps/Tools: Cisco Call Manager
*Native e-mail: E-mail functionalities built directly into the tool/application providing a user the capability to send and/or receive e-mail. These e-mails don't have to just be person-to-person, they can be triggered by a system event like a workflow approval or user action.
Examples:
A tool that sends an e-mail when a process fails.
An application sends an e-mail when there's been a ticket status change.
A project management app that sends task reminders or program updates.
With SMTP enabled, CUCM is able to send emails to designated email addresses when certain conditions occur such as Alarms. The events generating emails are set by the administrator. No emails are generated unless specifically configured to do so. CUCM cannot receive emails.
Does this answer your question?
Maren
