CUC voice-port register to CUCM ISSUE
mr.marslin
DAER SIr,
I config the PhoneSystem @CUC, Order the AXL server.
But the Voice-Port always register to CUCM-A.
When CUCM-A disconnect,  the voice-port can not move to others.... @@"
2 Accepted Solutions
Jaime Valencia
AXL has nothing to do with VM ports registering to CUCM. That's for synchyng AXL info, registration is SCCP.
You need to configure the CUCM group and apply it to the DP of VM ports and on CUC side configure the servers to which they should register and the order under the port group.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Rob Huffman
Hi there,
Just wanted to add a note to the good tips from my friend Java +5
Can you check these settings in CUC for the "Secondary" server config;
Step 32 On the Edit Servers page, do the following substeps if the Cisco Unified CM cluster has secondary servers. Otherwise, skip to Step 33.
a. Under Cisco Unified Communications Manager Servers, click Add.
b. Enter the following settings for the secondary Cisco Unified CM server and click Save.
Table 6-16     Settings for the Cisco Unified Communications Manager Servers
Field
Setting
Order
Enter the order of priority for the Cisco Unified CM server. The lowest  number is the primary Cisco Unified CM server, the higher numbers are  the secondary servers.
IP Address or Host Name
Enter the IP address (or host name) of the secondary Cisco Unified CM server.
Port
Enter the TCP port of the Cisco Unified CM server that you are  integrating with Cisco Unity Connection. We recommend that you use the  default setting.
TLS Port
Enter the TLS port of the Cisco Unified CM server that you are  integrating with Cisco Unity Connection. We recommend that you use the  default setting.
Server Type
Click Cisco Unified Communications Manager.
http://www1.cisco.com/en/US/docs/voice_ip_comm/connection/7x/integration/cucm_sccp/guide/cucintcucmskinny050.html
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Jaime Valencia
java
java
Rob Huffman
Hi there,
Field
Setting
Order
Port
TLS Port
Server Type
Cheers!
Rob
