CUCIMOC and CUPC8
d.marsh
Level 4
Level 4
Is there anyway to get CUCIMOC and CUPC8 installed on the same PC.
Yes I know they are both CSF devices and I don't want to do it in a live enviroment just in our labs, support machines and Customer demo enviorments. I don;t want them to run at the same time I just want the ability to install them both on the same machine and run either one of them up (but not both at the same time)
skilambi
It won't be supported but you should be able use vm in your laptop and run both of them simultaneously
Srini
Good question Dave,
Other than having to emulate separate machines, is there really no way of demonstrating the two clients on the same PC?   Surely someone out has come up with some smart way of doing things??
