CUCM 12.5 CLI admin login issues passwd: Authentication token manipulation error
rwalker0111
Anybody run into this or know of the fix?
SSH
administrator@x.x.x.x
password:
WARNING: Your password has expired.
You must change your password now and login again!
Changing password for user administrator.
Changing password for administrator.
(current) UNIX password:
New Password:
Retype new password:
Jaime Valencia
If this is a new install, it might be this bug:
CSCvq82632
You can run the command: "show password complexity character" to see which rules are being applied and try to create a password that matches them.
java
if this helps, please rate
Seems like they are all disabled.
admin:show password complexity character
Password character complexity rules to be used for OS user passwords are:
Character Sets      rule : disabled
Password Difference rule : system default is in effect
Character MaxRepeat rule : disabled
Password History    rule : disabled
admin:
