CUCM 14 / Legacy Paging / Informacast Basic
MJD52
We are looking at upgrading our phones from a traditional PBX to Cisco IP. I am familiar with the CIsco IP and have deployed them before. However, the time I worked with them with overhead paging was a long time ago and was using unicast through an interface on the router to a bogen amp. It appears now, Informacast is included to some degree with basic and other licenses. I think the 50 device limitation will be ok, however, I noticed the Legacy Paging Interface is only for Advanced licenses. Is there anything else that can be utilized in the "basic" license to utilize paging to a single amp in a building? like an ATA or FXO? Or would I be better off utilizing a line group?
Thanks all.
It didn't use Informacast at all. Ceiling speakers, and analog page control/amplifier, and then the SIP device registered with call manager.
5 Replies 5
Jaime Valencia
See here:
https://www.singlewire.com/informacast-basic-paging
You can also use any 3rd party paging solution you want along with informacast, you'd need to discuss wih the 3rd party vendor which interface and / or protocol would be required.
A line group has NEVER been a solution for paging.
java
if this helps, please rate
Sorry I meant paging group.
I have had excellent results with page controls from Valcom. There make a PoE powered SIP device (PagePro VIP-201A) that will register with CM. If you have legacy analog type paging, that is a very easy integration. You can likely take a connection from the SIP page control direct to an existing page control.
Did you use this device with Informacast basic or how did you utilize it
within the deployment?
