CUCM 6 and PSTN connection with 1760 Router
The.Sorrow
I just got phone service from Cox and am having issues getting inside -> outside and outside -> inside dialing working. I have a C1760 acting as my MGCP gateway with an FXO card. I have a DN that rings all my phones that i want my inward calls to route to (2000). All local 4-digit dialing works a-okay.
In short, the call flow i want is PSTN -> Router -> 2000 -> hunt group for all phones.
And my router config:
Building configuration...
Current configuration : 2507 bytes
version 12.4
hostname R2
no aaa new-model
resource policy
clock timezone PST -8
clock summer-time CDT recurring
voice-card 2
no ip domain lookup
ip domain name my.domain
ip host CUCM 10.50.0.225
ip name-server 10.50.0.250
interface FastEthernet0/0
description description Port to Core Switch
ip address 172.16.0.250 255.255.255.252
speed 100
full-duplex
router ospf 100
log-adjacency-changes
network 172.16.0.248 0.0.0.3 area 0
ip default-gateway 172.16.0.249
voice-port 2/0
groundstart auto-tip
timing hookflash-out 50
connection plar opx 2000
voice-port 2/1
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.50.0.225
ccm-manager config
mgcp
mgcp call-agent CUCM 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 99920 pots
service cmgpapp
destination-pattern 1[2-9]..[2-9]......
port 2/0
As always, any and all help is greatly appreciated.
Jaime Valencia
You need to explain the exact behavior you're seeing in order to get help
Is the GW registered??
What do you see/hear on the phone??
What do you see in the debugs??
Is the Inbound CSS config correct??
java
if this helps, please rate
Jaime Valencia
java
I have made some progress since posting this. I recieve calls from the PSTN correctly now. I had to set the attendant DN in CUCM to the pilot number for my hunt group and a destination-pattern dial peer specifying CUCM as the ipv4 target. In short, inward dialing works great now. Now outbound calling seems to be having issues. The gateway is registered and when i dial out using 10-digit dialing for a local number i get a fast busy signal. At the same time, the gateway throws this mass of logging events with "debug voice ccapi all"
*Jul  4 00:05:33.752: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   CALL_ERROR_INFORMATIONAL; Call Id Is Invalid=-1
*Jul  4 00:05:33.752: //-1/xxxxxxxxxxxx/CCAPI/ccDigitDialStop:
   CALL_ERROR_INFORMATIONAL; Call Entry Is Not Found
*Jul  4 00:05:33.752: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x8443876C, Interface Type=6, Destination=702*******, Mode=0x9,
   Call Params(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=702*******(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=A000000001e82cb8000000F5)
*Jul  4 00:05:33.756: //153/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
*Jul  4 00:05:33.756: //153/C1AA176580A4/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=153
*Jul  4 00:05:33.756: //153/C1AA176580A4/CCAPI/cc_set_voice_port_value:
   CC_IF_TELEPHONY: Echo=1, Playout=1
*Jul  4 00:05:33.756: //153/C1AA176580A4/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Jul  4 00:05:33.756: //153/C1AA176580A4/CCAPI/ccCallSetContext:
   Context=0x82516208
*Jul  4 00:05:33.756: //-1/xxxxxxxxxxxx/CCAPI/ccCodecPresent:
   codec 17
*Jul  4 00:05:33.760: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x842C5A00, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
*Jul  4 00:05:33.760: //154/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=0, Call Entry(Call Count On=TRUE, Incoming Call=FALSE)
   Total Call Count=1
*Jul  4 00:05:33.760: //154/C1AA176580A4/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=154
*Jul  4 00:05:33.760: //154/C1AA176580A4/CCAPI/cc_set_voice_port_value:
   CC_IF_RTP: vad=0, modem_pro=2, modem_codec=1
*Jul  4 00:05:33.764: //154/C1AA176580A4/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
*Jul  4 00:05:33.764: //154/C1AA176580A4/CCAPI/ccCallSetContext:
   Context=0x82516160
*Jul  4 00:05:33.768: //154/C1AA176580A4/CCAPI/cc_api_call_connected:
   Interface=0x842C5A00, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Jul  4 00:05:33.768: //154/C1AA176580A4/CCAPI/cc_api_call_connected:exit@5005
*Jul  4 00:05:33.772: //154/C1AA176580A4/CCAPI/cc_incr_if_call_volume:
   Remote IP Address=0.0.0.0, Hwidb=FastEthernet0/0
   Total Call Count=1, Voip Call Count=1, MMoip Call Count=0
*Jul  4 00:05:33.772: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Jul  4 00:05:33.776: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Jul  4 00:05:33.776: //0/xxxxxxxxxxxx/CCAPI/cc_api_get_ic_leg_obtained_numbers:
*Jul  4 00:05:33.776: //153/C1AA176580A4/CCAPI/cc_api_call_disconnected:
   Cause Value=17, Interface=0x8443876C, Call Id=153
   Call Entry(Responsed=TRUE, Cause Value=17, Retry Count=0)
*Jul  4 00:05:33.780: //154/C1AA176580A4/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Start Calling Accounting;
   Call Entry(Incoming=FALSE)
   Cause Value=47, Call Entry(Disconnect Cause=0)
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
*Jul  4 00:05:33.780: //153/C1AA176580A4/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=17)
*Jul  4 00:05:33.784: //153/C1AA176580A4/CCAPI/ccCallDisconnect:
   Cause Value=47, Call Entry(Disconnect Cause=17)
   Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
*Jul  4 00:05:33.784: //153/C1AA176580A4/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Jul  4 00:05:33.788: //153/C1AA176580A4/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x1, Call Id=153
   Flag=FALSE
*Jul  4 00:05:33.792: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif:
   ExpectFactor=0xA
*Jul  4 00:05:33.792: //154/C1AA176580A4/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x1, Call Id=154
   Flag=FALSE
*Jul  4 00:05:33.792: //154/C1AA176580A4/CCAPI/cc_decr_if_call_volume:
   Total Call Count=0, Voip Call Count=0, MMoip Call Count=0
*Jul  4 00:05:33.792: //154/C1AA176580A4/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x842C5A00, Tag=0x0, Call Id=154,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
*Jul  4 00:05:33.796: //154/C1AA176580A4/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
*Jul  4 00:05:33.796: //154/C1AA176580A4/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
*Jul  4 00:05:33.796: //154/C1AA176580A4/CCAPI/cc_delete_call_entry:
   Total Call Count=1, Call Entry(Call Count On=TRUE, Incoming Call=FALSE)
   Total Call Count=0
*Jul  4 00:05:33.800: //153/C1AA176580A4/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8443876C, Tag=0x0, Call Id=153,
   Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
*Jul  4 00:05:33.800: //153/C1AA176580A4/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
*Jul  4 00:05:33.800: //153/C1AA176580A4/CCAPI/cc_delete_call_entry:
   Deleting profileTable[0x8472C664]
debug mgcp packets output:
*Jul  4 00:48:48.914: MGCP Packet sent to 10.50.0.225:2427--->
NTFY 775945683 *@R2.my.domain MGCP 0.1
X: 0
O:
*Jul  4 00:48:48.914: MGCP Packet received from 10.50.0.225:2427--->
200 775945683
*Jul  4 00:48:49.535: MGCP Packet received from 10.50.0.225:2427--->
CRCX 478 AALN/S0/SU2/0@R2.my.domain MGCP 0.1
C: A000000001e82ccb000000F5
X: 0
L: p:20, a:PCMU, s:off, t:b8
M: recvonly
R: H/oc, H/of, L/hd
S: H/sup(addr(7,0,2,*,*,*,*,*,*,*))
Q: process,loop
*Jul  4 00:48:49.539: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Jul  4 00:48:49.539: //-1/xxxxxxxxxxxx/CCAPI/ccDigitDialStop:
*Jul  4 00:48:49.543: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, CallCount On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=A000000001e82ccb000000F5)
*Jul  4 00:48:49.543: //163/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
*Jul  4 00:48:49.543: //163/CCDFC9F480A9/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=163
CobraUnit-R2#C9F480A9/CCAPI/cc_set_voice_port_value:
*Jul  4 00:48:49.547: //163/CCDFC9F480A9/CCAPI/ccIFCallSetupRequestPrivate:
*Jul  4 00:48:49.547: //163/CCDFC9F480A9/CCAPI/ccCallSetContext:
   Context=0x82516208
*Jul  4 00:48:49.547: //-1/xxxxxxxxxxxx/CCAPI/ccCodecPresent:
   codec 17
*Jul  4 00:48:49.547: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, CallCount On=TRUE,
*Jul  4 00:48:49.551: //164/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=1
*Jul  4 00:48:49.551: //164/CCDFC9F480A9/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=164
*Jul  4 00:48:49.551: //164/CCDFC9F480A9/CCAPI/cc_set_voice_port_value:
*Jul  4 00:48:49.551: //164/CCDFC9F480A9/CCAPI/ccIFCallSetupRequestPrivate:
*Jul  4 00:48:49.551: //164/CCDFC9F480A9/CCAPI/ccCallSetContext:
   Context=0x82516160
*Jul  4 00:48:49.559: //164/CCDFC9F480A9/CCAPI/cc_api_call_connected:
   Connection Handle=0
*Jul  4 00:48:49.559: //164/CCDFC9F480A9/CCAPI/cc_api_call_connected:exit@5005
*Jul  4 00:48:49.559: //164/CCDFC9F480A9/CCAPI/cc_incr_if_call_volume:
*Jul  4 00:48:49.563: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Jul  4 00:48:49.563: //0/xxxxxxxxxxxx/CCAPI/cc_api_get_ic_leg_obtained_numbers:
*Jul  4 00:48:49.567: //163/CCDFC9F480A9/CCAPI/cc_api_call_disconnected:
   Cause Value=17, Interface=0x8443876C, Call Id=163
*Jul  4 00:48:49.567: //164/CCDFC9F480A9/CCAPI/ccCallDisconnect:
*Jul  4 00:48:49.571: //164/CCDFC9F480A9/CCAPI/ccCallDisconnect:
*Jul  4 00:48:49.571: //163/CCDFC9F480A9/CCAPI/ccCallDisconnect:
*Jul  4 00:48:49.575: //163/CCDFC9F480A9/CCAPI/cc_api_get_transfer_info:
*Jul  4 00:48:49.575: MGCP Packet sent to 10.50.0.225:2427--->
401 478 Already off hook
*Jul  4 00:48:49.575: //163/CCDFC9F480A9/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x1, Call Id=163
   Flag=FALSE
*Jul  4 00:48:49.579: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif:
   ExpectFactor=0xA
*Jul  4 00:48:49.579: //164/CCDFC9F480A9/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x1, Call Id=164
   Flag=FALSE
*Jul  4 00:48:49.583: //164/CCDFC9F480A9/CCAPI/cc_decr_if_call_volume:
*Jul  4 00:48:49.583: //164/CCDFC9F480A9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x842C5A00, Tag=0x0, Call Id=164,
*Jul  4 00:48:49.583: //164/CCDFC9F480A9/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
*Jul  4 00:48:49.587: //164/CCDFC9F480A9/CCAPI/cc_delete_call_entry:
   Total Call Count=0
*Jul  4 00:48:49.587: //163/CCDFC9F480A9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8443876C, Tag=0x0, Call Id=163,
*Jul  4 00:48:49.591: //163/CCDFC9F480A9/CCAPI/cc_api_call_disconnect_done:
*Jul  4 00:48:49.591: //163/CCDFC9F480A9/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
*Jul  4 00:48:49.591: //163/CCDFC9F480A9/CCAPI/cc_delete_call_entry:
*Jul  4 00:48:49.595: MGCP Packet received from 10.50.0.225:2427--->
DLCX 479 AALN/S0/SU2/0@R2.my.domain MGCP 0.1
X: 0
S:
*Jul  4 00:48:49.595: MGCP Packet sent to 10.50.0.225:2427--->
400 478 Active msg is aborted by dlcx
*Jul  4 00:48:49.599: MGCP Packet sent to 10.50.0.225:2427--->
250 479 already deleted connection
*Jul  4 00:48:49.603: MGCP Packet received from 10.50.0.225:2427--->
RQNT 480 AALN/S0/SU2/0@R2.my.domain MGCP 0.1
X: 0
R: L/hd
Q: process,loop
*Jul  4 00:48:49.603: MGCP Packet sent to 10.50.0.225:2427--->
200 480 OK
*Jul  4 00:48:49.607: MGCP Packet received from 10.50.0.225:2427--->
RQNT 481 AALN/S0/SU2/0@R2.my.domain MGCP 0.1
X: 0
R: L/hd
S:
Q: process,loop
*Jul  4 00:48:49.611: MGCP Packet sent to 10.50.0.225:2427--->
200 481 OK
CobraUnit-R2#
*Jul  4 00:49:03.915: MGCP Packet sent to 10.50.0.225:2427--->
NTFY 775945684 *@R2.my.domain MGCP 0.1
X: 0
O:
*Jul  4 00:49:03.915: MGCP Packet received from 10.50.0.225:2427--->
200 775945684
CobraUnit-R2#
*Jul  4 00:49:18.915: MGCP Packet sent to 10.50.0.225:2427--->
NTFY 775945685 *@R2.my.domain MGCP 0.1
X: 0
O:
*Jul  4 00:49:18.915: MGCP Packet received from 10.50.0.225:2427--->
200 775945685
CobraUnit-R2#
*Jul  4 00:49:33.916: MGCP Packet sent to 10.50.0.225:2427--->
NTFY 775945686 *@R2.my.domain MGCP 0.1
X: 0
O:
*Jul  4 00:49:33.916: MGCP Packet received from 10.50.0.225:2427--->
200 775945686
*Jul  4 00:49:48.917: MGCP Packet sent to 10.50.0.225:2427--->
X: 0
O:
*Jul  4 00:49:48.917: MGCP Packet received from 10.50.0.225:2427--->
200 775945687
CobraUnit-R2#
*Jul  4 00:50:03.917: MGCP Packet sent to 10.50.0.225:2427--->
X: 0
O:
*Jul  4 00:50:03.917: MGCP Packet received from 10.50.0.225:2427--->
200 775945688
Here is my new router config as well:
voice-port 2/0
supervisory disconnect dualtone mid-call
signal groundStart
caller-id enable
voice-port 2/1
ccm-manager mgcp
ccm-manager config
mgcp
mgcp sdp simple
dial-peer voice 100 voip
destination-pattern 2000
session target ipv4:10.50.0.225
service mgcpapp
destination-pattern 9T
port 2/0
dial-peer voice 101 pots
service mgcpapp
port 2/0
dial-peer voice 102 pots
service mgcpapp
destination-pattern [2-9]..[2-9]......
port 2/0
I also have a route Group/List/Pattern that include the digits i am dialing, pointing to the 1760 voice router.
