09-12-2013 06:19 PM - edited 03-19-2019 07:16 AM
Hello all,
I am running into an issue where I receive the error "No valid upgrade options were found" when I attempt to initiate an in-place direct upgrade from CUCM version 7.1.5.3000-1 to version 9.1.2.1000-28 using SFTP.
I have verified I am using the correct SFTP directory and even used another folder containing valid .cop files. When using this folder I see the .cop files, but not the 9.1.2 upgrade file so I know the server is hitting the correct directory.
I have loaded “ciscocm.refresh_upgrade_v1.2.cop” file before the upgrade.
The upgrade file I am attempting to use is “Bootable_UCSInstall_UCOS_9.1.2.10000-28.sgn.iso”.
Do I possibly need to download the non-bootable version to perform an upgrade via SFTP?
Thanks in advance for any assistance!
09-12-2013 06:31 PM
hi
Use the download file shown in the below link
https://supportforums.cisco.com/message/4009240#4009240
Ronak Patel
Rate all helpful post by clicking stars below the answer.
09-12-2013 06:34 PM
Are you using UCs server or Vmware. If yes, try to do it via the DVD option.. That would be good. I believe your current file is good only.
Ronak Patel
09-12-2013 06:39 PM
Thanks for the reply. I'm running on MCS servers. I'll try the different files tomorrow or see if I can get the customer to burn the ISO to a DVD and provide an update.
Sent from Cisco Technical Support Android App
09-12-2013 06:41 PM
Hi Robert,
Just fyi.. Why are you not doing direct upgrade. Details are in below link. Your current release and traget release both support direct upgrade procedure.
https://supportforums.cisco.com/docs/DOC-35163#comment-20432
Ronak Patel
09-12-2013 06:45 PM
A direct upgrade is what I am attempting to do.
09-14-2013 11:12 AM
I downloaded the non bootable file from Cisco and all went well. To anyone reading this...Be advised...this upgrade is Very Long. A 7500 phone cluster on a 7945 server took 4.5 hrs to upgrade the Publisher and about 3.5 hrs per Subscriber.
