09-21-2012 11:44 AM - edited 03-19-2019 05:34 AM
Hello Forum,
Hope this is an easy one for you guys.
I am trying to accomplish the following and not sure if its possible.
Ex.
Any help would be appreciated as I am not sure where to change the settings to make this happen.
Thanks in advance,
LS
Solved! Go to Solution.
09-21-2012 01:08 PM
You don't need a special VM profile in this case. By setting the alternate extension on the mailbox for 8888 to 1111, Unity or Unity Connection (whichever you have) will send calls to either number to the greeting for 8888.
Hailey
Please rate helpful posts!
09-21-2012 12:15 PM
Assuming x1111 does not need a dedicated voicemail, you could do the following:
Ensure that x1111 has the correct VM profile and set the CFB/CFNA settings to forward to VM as usual. On the mailbox for 8888, set an alternate extension of 1111.
Hailey
09-21-2012 01:04 PM
How do you setup a new VM profile to point it to mailbox 8888?
09-21-2012 01:08 PM
Hailey
09-21-2012 01:39 PM
Thank you. That worked exactly as I needed it to.
