CUCM 9.1 SIP Trunk to SME 9.1
jays_jara
Hi Guys,
We have a CUCM 9.1 and a SME 9.1 which have SIP Trunk between the two. I was trying to figure out if there is a way to determine via RTMT or any other tool on how to determine how many calls are in that trunk?
Also, from the tool if there is any that can provide more details information about the call like the CDR.
Setup:
CUCM 9.1 ---------SIP Trunk--------- SME 9.1
Thanks to all who will respond.
You can check the active calls from RTMT under the performance section.
go to Performance-->Cisco SIP-->calls Active..attached is the screenshot for the same.
you can also get the detailed information of active calls from the 3rd part Variphy tool.
-Venkatesh.
P.S Please rate helpful Post.
Thanks! Venkatesh
This help for capacity planning.
Jays
