CUCM and IMP configuration and validation error
sibun
Hello team,
I need assistance in setting up IMP ver 10.5.2.20000 and CUCM 10.5.2.13900. Every time the IMP setup fails at the network connectivity validation with the attached error message, please see attachment.
I have added the IMP IP address in the CUCM System -> Server menu.
Thank you in advance,
Sibusiso.
In the screenshot you have entered Hostname as Lab-CUCM, But hostname is CUCM per below output
admin:show status
Host Name          : CUCM
6 Replies 6
Mohammed Khan
can you provide the output of below from CUCM Publisher
show network cluster
show myself
show status
show network eth0
run sql select * from processnode
Hi Mohammed,
Thank you for your response and please find attached the requested output of the show commands,
Thank you,
Sibusiso
admin:show status
Host Name          : CUCM
Hi Mohammed,
Thank you for your assistance, the IMP installed successfully.
Sibusiso.
Chris Deren
Make sure you forward and reverse DNS records for all servers are correct.
Are you talking with below pic?
