12-04-2016 01:04 AM
I am facing an issue for login in CUCM OS Admin on CLI, while logging in as I am giving the username and password, it shutdown the putty, I tried through console as well, after giving the username and password, it's again showing the login page asking username and password.
Please advise for the same as I need to troubleshoot replication issue.
Regards:
Nabeel
12-04-2016 02:42 AM
Hi Nabeel,
could be an issue with privilege level of OS username?
are u able to login through GUI using same OS credentials
12-04-2016 02:47 AM
Hello Aman,
Thanks for your response
Yes I am able to login through GUI using OS credentials.
Also I am able to login cucm sub node in CLI using os credentials
12-04-2016 04:07 AM
Hi ,
What is CUCM version?
I was just going through the bug .
(1)
| Known Fixed Releases: |
(2)
| Known Affected Releases: |
(1)
(2)
12-04-2016 04:24 AM
Here is the exact version of CUCM we have installed
System version: 9.1.2.10000-28
could you please advise how can I resolve the same
12-04-2016 04:39 AM
Do u have any other applications like UCCX/Unity installed in setup ? If yes, are u able to login through same putty ?
regds,
aman
12-04-2016 05:04 AM
Yes we have the unity connection with same version and I am able to login it's OS Admin credentials through putty and through console as well.
Moreover in cucm subscriber nodes also I am able to login using OS Admin credentials.
12-04-2016 05:55 AM
hi,
can u share the output of command
show myself
and show account from subscriber
