CUCM - Creating/Updating Speed Dials using SQL
andrew.m
Hi All - I'm new to the SQL portion of UCM and was wondering if anyone had some sql strings for the following scenarios?
  • Creating Speed Dials for one and more than one phone(s) - both scenarios
  • Updating Speed Dials for one and more than one phone(s) - both scenarios
  • Can UDP profiles be done in the above manor? If so what is the stings for those?
  • Is there a way to associate userID to both the phone and line using SQL strings? If so, what would they look like
Thank You in advance to the amazing Cisco Support community!
Hi there
https://developer.cisco.com/docs/axl-schema-reference/
Hope this helps
Cheers
Rath!
***Please rate helpful posts***
6 Replies 6
Jaime Valencia
That's the least recommended way to do any MACD in CUCM, and not something we encourage or support (few exceptions when there is absolutely no other way to do it, and most likely TAC will provide the exact instructions)
You should use either BAT, the CUCM GUI, or if you want to script this, then use AXL.
java
if this helps, please rate
Thanks Jaime!
Would you have any beginner advice / website or guides that would help me with AXL?  Perhaps some steps?
All the AXL documentation, schema, etc can be found at DevNet, and you want to use a program like SoapUI for this to begin with.
java
Thank You
Hi there
Hope this helps
Cheers
Rath!
Thanks Ratheesh!  That is extremely helpful
