CUCM: Dial one number and call many user simultaneously
nicanor00
I have CUCM 8.5
Is it possible to configure one number XXXX so when I dial number XXXX I call many user(predefined group of user) simultaneously ?
22 Replies 22
Is this still the case with 11.5?
If so, can products like informa-cast or syn-apps be leveraged to make this work?
is it possible to use hunt pilot ?
If you want to end up with a conference, no, still not a feature.
If you want to reach out to many users at a time, and have one answer the call, then use a line group with any algorithm.
Informacast is for paging, so yeah, if you want paging, you can use it.
java
if this helps, please rate
Correct and agreed
It can be done using cisco IOS gateway, TCL script and CME.
I have implemented and it is working.
It has nothing to do with callmanager's version. Call Manager just forwards the group call number to the voice gateway.
TCL script running on a callmanager express, which creates conference room and makes predefined called numbers  join the conference room solves the problem.
I have implemented and it is working.  You need IOS gateway.
You can do Blast Dial Conference bridge using InformaCast - Conference Call Plugin
https://www.singlewire.com/conference-call
I assume that your script "Broadcast" is a better solution.
