CUCM IM&P 15SU2: issues with IMDB replication
raziel1978kain
we have a CUCM IM&P 15SU2 cluster (2 nodes) and we have issues with the IMDB replication (which are causing issues with the Jabber logins).
Based on the document at the link
https://www.cisco.com/c/en/us/support/docs/unified-communications/jabber/212471-jabber-login.html#toc-hId-709326440
we have followed the steps to resolve the IMDB replication issues but, after the procedure, we still have the following:
admin:utils imdb_replication status
Running IMDB DSN (ttsoft, ttlogin, ttreg) replication checks on all nodes in cluster ...
NOTE: For diagnostic test to run, ports 6603, 6604 & 6605 must be open on any firewalls between IM&P Servers
Sub Cluster Name / Id :: DefaultCUPSubcluster / 1000
Checking connectivity & removing old data prior to running diagnostic
Cisco Presence Datastore Replication
<CUCM IM&P Subscriber> -> <CUCM IM&P Publisher> Failed
<CUCM IM&P Publisher> -> <CUCM IM&P Subscriber> Failed
Gathering Debug Info for failed DSN ... please wait
Traceback (most recent call last):
File "/usr/local/imdb/bin/imdb.py", line 539, in test_imdb
test_imdb_ttsoft_replication(nodename1,nodename2,subclustername)
File "/usr/local/imdb/bin/imdb.py", line 253, in test_imdb_ttsoft_replication
gather_failed_replication_info(node1, node2, TTSOFT_PORT)
File "/usr/local/imdb/bin/imdb.py", line 196, in gather_failed_replication_info
a.write_to_file("%s\n" % (result[0].decode('utf-8')))
AttributeError: 'str' object has no attribute 'decode'
admin:
N.B.: we have already checked that the ports 6603, 6604, and 6605 are open.
What's wrong?
TIA and regards.
Hello @Nithin Eluvathingal,
thanks for the link, but we already had checked the DB replication, which is fine; where we have issues is only with the IMDB (In-memory Database) replication, which is something else compared to the "classic" DB replication.
Regards.
As far as I know, both IMP and CUCM database troubleshooting remain the same. That’s why I sent you the link to fix the database.
What do the following commands say about the IMP nodes?
  • utils dbreplication runtimestate
  • utils diagnose test
  • utils network connectivity
Response Signature
at last, we had to solve the issue with the TAC, due to the following bug:
https://bst.cisco.com/bugsearch/bug/CSCwn54933
Regards.
