12-19-2018 12:45 AM
Hi all,
we have a customer with Cisco CUCM Version 11.5.1.15900-18.
Our System is the ascom IP-DECT. When we use a Hunt Group the Alerting Name contains wrong Information.
On the Display it's shown like this: "%22Test%22 (Test being a test name for Alerting Name).
But as you can see in the attached Image, in the "Alerting Name" Field it's only "Test" filled in.
With Wireshark, you can see the following String:
Huntpiloturi ="%22Test%22<sip:XXXXXXXXXX@IP.IP.IP.IP>"
Has anyone similar issues? What might cause this issue?
Best regards
Michael
Solved! Go to Solution.
01-20-2019 10:22 AM
It appears Cisco decided to create a defect for this behavior:
12-19-2018 04:55 PM
12-19-2018 11:59 PM
First, thanks for that quick reply!
Here you can see a screenshot of the Message Header Part from the Wireshark protocol debug:
Is there anything else you ned? I tried to paint over the private data black.
/Michael
12-21-2018 07:48 AM
01-20-2019 10:22 AM
01-21-2019 08:19 AM
Thank you very much for your help!
It seems to be fixed now. Good News for our customer.
