CUCM problem sync'ing users via LDAP
Difan Zhao
Level 5
Level 5
Hi experts,
I am having issue sync'ing the users from the LDAP directory. I had been running for an entire day. In the "LDAP Directory" page, the "Cancel Sync Process" is still lit. Under users, I still don't see anybody except the local ones... What should I do to troubleshoot?
Difan
Jaime Valencia
Start by double checking all of the information you used for the integration, and you can also review the LDAP sync logs.
java
if this helps, please rate
kaikai.wang
请问一下,这个问题你解决了吗?采用了什么方式,期待你的回复,谢谢。
Ratheesh Kumar
Hi there
Could you post the LDAP directory configuration. Hope no filters are configured in CUCM LDAP Config and make sure you have added the Last name in AD. Missing that is mostly the common mistake.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
CUCM LDAP configuration and make sure that you have added a surname in AD is effective, thank you for your help, to help you happy.
