09-18-2023 06:58 AM
I have an issue with our recording setup.
I have created the recording profile and secure sip trunk to our cube.
When I make a call, I see the call coming in, but the call is not sent to the recorder.
When I do 'debug voice dialpeer all' I see that the outgoing dial peer is matched, but my incoming dialpeer is not matched.
Result=NO_MATCH(-1) After All Match Rules Attempt
My incoming dial peer is configured with 'incoming called-number .' so it should match any incoming call.
I have also tried to match the dial peer on the ip of the cucm, but I have the same problem then.
Any ideas what else I can do?
Kind regards
Didier Derveaux
09-20-2023 05:42 AM
I concur with @b.winter there is no usable information in the shared output from the debugs. It just contains an inbound invite and then basically no more, only a SIP option ping dialog. With this it's not very useful.
Can you please check that your dial peers are in an operational state with "show dial-peer voice summary", see the below as an example from one of our system.
selurt-cube-01#sh dial-peer voice summary
dial-peer hunt 0
AD PRE PASS SESS-SER-GRP\ OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE VRF
1000 voip up up 0 nse NA
1010 voip up up map:1 0 nse SESS-SVR-GRP: 1 active NA
100 voip up up 0 syst NA
110 voip up up map:2000 0 syst SESS-SVR-GRP: 2000 active NA
For server-grp details please execute command:show voice class server-group <tag_id>
To see complete session target for ipv6 use 'sh running-config | section dial-peer <tag>
selurt-cube-01#
Explanation of the dial peers in the list, 1000 is the inbound from CM, 1010 is outbound to CM and 100 is inbound from a ITSP and 110 is outbound to the ITSP.
09-19-2023 08:27 AM - edited 09-19-2023 11:28 PM
There are a few things that sticks out in your configuration. I would suggest that you try with adding this.
voice service voip
ip address trusted list
ipv4 x.x.x.x
ipv4 y.y.y.y
voice class sip-options-keepalive 1
description Used for Server Group SIP OPTIONS PING
no voice class uri 101 sip
voice class uri CUCM sip
host ipv4:x.x.x.x
voice class uri REC sip
host ipv4:y.y.y.y
dial-peer voice 8000 voip
description Outbound dial peer to recording system
destination-pattern 8888$
voice-class sip options-keepalive
codec g711ulaw
dial-peer voice 1000 voip
description Inbound dial peer from CM
no voice-class sip options-keepalive
no incoming called-number .
incoming uri via CUCM
dial-peer voice 2000 voip
description Outbound dial peer to CM
destination-pattern 2...$
voice-class sip options-keepalive profile 1
codec g711ulaw
dial-peer voice 8100 voip
description Inbound dial peer from recording system
session protocol sipv2
session transport tcp tls
incoming uri via REC
voice-class sip bind control source-interface GigabitEthernet0/0/1
voice-class sip bind media source-interface GigabitEthernet0/0/1
dtmf-relay rtp-nte
srtp
codec g711ulaw
no vad
Also I would recommend you to upgrade IOS to something more recent than 16.9. That's back from the pre-color TV era.
09-19-2023 11:35 PM
OK Thanks, I will add this to the configuration. I am not on site now, but I will update you when I have done this.
